08-18-2014 09:34 AM
New powershot 320hs - I'm getting the green auto focus bars when shooting a image, but afterwards the display detail shows a white sq with yellow inside square on the image I shot and the second tiny image for AF check tells me it is not sharp. This happens often when shooting and I have to shoot several pictures of the same image before I get a sharp picture. I noticed better results with face detection on but I'm shooting plant images so I don't understand why this is happening? I have had other elphs without this problem.
Rose Gatto
08-20-2014 10:29 AM
Hi ballina!
Thank you for posting.
There are certain limitations on how close to the subject the camera can be and still achieve a focus lock. The yellow square indicates that the camera was unable to focus on the subject.
How close to the subject is the camera when you are focusing on it?
08-20-2014 04:03 PM
I was about 4 to 6 inches for a close up shot and I used the macro focus too. But I had that yellow square happen on some of my landscape pictures too. I finally got some sharp picture but I had to shoot several pictures to get it. I moved out to about 8 to 10 inches too. I will experiment with pictures far away and see how often the yellow square shows up.
Rose
08-20-2014 08:43 PM
In addition to how close, were you using the zoom at the same time? That will give you a hard time when doing macros if you get that close. As far as the landscape shots, might you have left it in macro mode when getting the shot? I've done that more than I'd like to admit!!
Steve M.
