need drivers for CANON ImageClass copier D320 for windows 8.1. Help!!
charlyd86
1 REPLY 1
Patrice
Whiz
Hi charlyd86.
The drivers are available for download at the Canon USA website.  Please follow the instructions below to download and install the drivers:
1.  Go to Canon's Support & Drivers website at:
http://www.usa.canon.com/cusa/support/consumer
2.  Enter D320 into the Model Name field, then click GO.
3.  Your operating system will be detected automatically. If you need to download the drivers for a computer running a different operating system, you can change the selection in the drop down.
4.  Expand the Drivers section by clicking the red triangle.
5.  Click on the file named [Windows 64bit] imageCLASS D340/D320/FAXPHONE L170/L120 C....
6.  Click the agreement checkbox and then select the "Download" button.
7.  Once the download is complete, double-click the file from its download location to begin the installation.  Downloaded files are saved in the specified folder in a self-extracting format (.exe format).  Double-click the files to decompress them.  A new folder will be created in the same area.  The new folder will have the same name as the compressed file.  Double-click the decompressed Setup folder and you will see two options for 'Setup'.  Double-click on the 'Setup' with the type 'Application'.  The "CARPS Driver Setup Wizard" will open.
I hope this information is helpful to you.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
