11-16-2013 04:47 PM
My new D530 is set for front and back printing as OFF yet it still prints front and back even though no instructions to do so.
Could this be a driver problem? They have told me my driver sent with the printer is not correct for Windows 8. I tried downloading one from the sight. It did not load. I can print but stuck in double sided mode even though says OFF. Any suggestions?
11-24-2013 09:01 AM
02-20-2014 12:11 PM
Go to "properties" not finishing. I have to do it every time I print. For some reason hooking this printer up causes my computer to default back to two sided every time I print. Annoying.
02-20-2014 01:37 PM
Sorry but I still do not see where I can change this setting. I can see under properties/general where the features show 2 sided printing but cannot see where I can change this. I have tried every tab and every option.
02-22-2014 12:40 PM
Hi dsscpa!
Canon does not support printing in virtual networks or operating systems, such as Parallels. I am including the steps to turn off 2-Sided printing in the Windows operating system below:
However, if these steps do not resolve your issue, you will need to contact Parallels technical support department for further assistance.
I hop this information is helpful to you. If you need assistance with printing from the Mac OS X operating system, please contact us at 1-800-OK-CANON (1-800-652-2666). Have a good day.
02-22-2014 12:44 PM
I do not have a "Print Style" selection under finishing.
I sure wish I had known that you do not support printing in virtual BEFORE i bought this printer.
So far Parallels support is no help either.
Frustrating.
02-22-2014 12:57 PM
Funny, I never see finishing in Windows 8.1 but under properties I do see one or two sided printing. That is what controls it for me, not the printer. I have to set it every time I use it.
If you have a Mac with Windows on it...I can say from 40 years in computers I have yet to see that combo work right although it may now in many ways...I'm a dinosaur.
Printer 530 I have is working well with my laptop and Windows..fast and clean..but have to set it to one side each time.
02-22-2014 12:58 PM
02-22-2014 01:01 PM
01-12-2018 11:45 AM
My question is actually about copying, not printing. For some reason, I can not copy two-sided any longer. When I click on the 2 sided button on the printer, the option is grayed out. Any suggesstions on how to be able to copy 2 sided again? I have a D530. Thank you!
11-21-2014 10:43 PM
Some applications on the Mac don't have this setting like Adobe Reader 11.0.09 (on Mac OS 10.10). Would we contact them about adding this feature?
As a workaround to print PDF's, one can use Mac's Preview application that does have this option.
04-21-2017 12:56 PM
I was having the same problem, expecially in Word. If you poke around in the printer dialog box, under paper handling there's something called "long edge binding" set as the default. Change that to "none." Problem solved.
@jessasdad wrote:I have the same problem on my iMac. How do you do this on a Mac?
