10-15-2015 06:31 AM
Hi - I have a imageFormula P-208II scanner and when I scan (no matter what options I select) I get the following error:
The filename, directory name, or volume label syntax is incorrect
I even taken it so the destination folder is C root (Windows 7)
The scanner works on another laptop but just stopped working on this for no reason.
Any ini file or registry hacks to get it working again (multipay re-installs BTW)
