‎08-27-2023
04:21 PM
‎08-29-2023
09:15 AM
I can not set up two-sided automatic scanning, has anyone solved this problem?
‎08-27-2023 04:25 PM
I load two-sided color originals into the feed tray, select a two-sided color copy on the display, as a result, only the first sheet is made a two-sided copy, the rest of the sheets are copied single-sided, help with advice, what is going wrong?
‎09-29-2023 08:04 PM - edited ‎09-29-2023 08:04 PM
I have a similar issue. There is no option for double-sided printing. I've installed MF Scan Utility and it's not present in there either.
‎11-10-2023 02:17 PM
Hello Yulian_23,
The auto document feeder on the MF751Cdw does not have the ability to perform automatic duplex scans. To scan both sides of the document, you would have to flip the pages over manually to scan the other side. You can view the MF751 specifications using the link HERE.
