09-09-2025
06:24 PM
06:35 PM
StevenMOD
My MF654Cdw will not scan. The drivers and scan utility are installed. I get a 255.0.0 error message. Any help would be appreciated.
09-15-2025 08:51 PM
This thread can be marked solved. The solution provided in the link above solved the user's problem.
09-09-2025 07:14 PM
Can you share the version and build of the operating system you're using the printer with?
Did scanning work previously or is this a new issue? Did something change?
How is the printer connected and to what?
09-09-2025 07:26 PM
Win11 pc newest version 24H2 build 26100.5074. New issue using USB connection.
09-10-2025 03:26 PM - edited 09-10-2025 03:29 PM
This is what happens when I try to use MF Scan after selecting documents. The item to scan is letter size.
09-13-2025 04:09 PM
Is anyone out there that can help. No one is replying.
09-15-2025 03:42 PM
MF Scan Utility does not work with USB connection. Is there any way to set it up?
09-15-2025 05:24 PM
I responded to your second post.
https://community.usa.canon.com/t5/Office-Printers/Scanner-doesn-t-work/td-p/568289
09-15-2025 08:51 PM
