01-15-2020 07:02 PM - last edited on 11-15-2024 09:07 AM by Danny
how do I turn off the beeping sounds on the Image Class MFb42dw? It gets really annoying after a while
01-17-2020 01:08 PM - edited 01-17-2020 01:09 PM
Hi JCassiW.
To change the sound, look on the left side of the operation panel for the "Volume" indication. There's a small button on the left side of the panel by that marking that brings up the volume and sound settings.
Hi JCassiW.
01-17-2020 06:57 PM
Thank you
11-18-2020 06:08 PM
That turns it down momentarily and then it starts beeping all over again. I went into the menu on the panel and turned all of the sounds to off then clicked apply and it still beeps everytime a page prints. I have to be missing something. This is driving me crazy. I'm not trying to back up a garbage truck. What is the purpose of all these beeps? Can anyone advice a solution?
12-20-2020 11:51 PM - edited 12-21-2020 12:00 AM
I found out it was my UPS that was being overloaded causing the loud beeping. Thx
03-24-2021 09:38 AM
Did you resolve this beeping issue? I can't turn mine off either. Beeps every time a page prints.
04-07-2021 02:16 PM
Yeah I did what Darius said the button is on the side
03-20-2024 07:57 PM
That button on the side turns mine down but not off. I don't need it to beep when it's done printing. The printing noise is way louder than any printer I've had before, so I know when it's done. I just don't need the beep waking up people in the house. I went through all the menu settings but can't find a way to disable it.
06-01-2024 08:33 PM
After pressing the side volume button, press the 'Other Volume Set.' on the bottom left of the screen and then switch the Job Done Tone to Off. Make sure you hit Apply on that screen and then Apply again on the next screen. This worked for me.
11-15-2024 09:02 AM
For users where this method doesn't work (I never get a 2nd 'Apply' notification), what else is there to try? I've gone through multiple On/Off/Apply experiments and no change. A single page print has a loud beep at the beginning and another beep or three on the tail end. I'm tempted to take the printer apart to pull the speaker cable but really would like to find a non-invasive solution. Canon experts -- any ideas? Thanks!
