imageCLASS MF642Cdw: Can't get envelopes printed, Mac Sonoma 14.6.1
PINCKERTINC
I can't Get envelopes printed.
Thanks. Erny
8 REPLIES 8
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, let us know how are you connecting? Is there an exact error message?
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
mreg
Rising Star
You really think that's enough information for anyone to help you?
PINCKERTINC
No signs. I put in some paper and printed with the same as the envelopes. But when I put envelopes it would not print.
Envelopes can be loaded into the paper cassette in lieu of paper or one at a time using the multipurpose feeder.  You can use the print driver or Microsoft word to print envelopes.
Here are additional instructions,
https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-basicope-papers_pset-envelope.html...
I am using the printed envelopes as instructed. However, it does not print.
I have put regular paper  to does print the dimension envelopment .
Erny
Sorry but I'm not following your post.  First, you said you couldn't print on envelopes. Then you said you're using a printed envelope and now you're talking about dimension envelopment.
If you don't mind, could you please  rephrase whatever it is that you're doing. Thanks
Sorry for confusion.
  1. Still cannot print on envelops.
  2. I took regular piece on paper 8.5 x 11 see if I can see printing on same on size as the envelope. Yes it printed. So nothing is wrong with printer.
What happens exactly when you insert the envelope into the manual feed slot?
