11-09-2024
07:54 PM
11:11 PM
Tiffany
I can't Get envelopes printed.
Thanks. Erny
11-09-2024 11:10 PM
Welcome to the forum!
So that the Community can help you better, let us know how are you connecting? Is there an exact error message? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
11-10-2024 08:51 AM
You really think that's enough information for anyone to help you?
11-10-2024 01:15 PM
No signs. I put in some paper and printed with the same as the envelopes. But when I put envelopes it would not print.
11-10-2024 02:18 PM
Envelopes can be loaded into the paper cassette in lieu of paper or one at a time using the multipurpose feeder. You can use the print driver or Microsoft word to print envelopes.
Here are additional instructions,
11-17-2024 04:45 PM
I am using the printed envelopes as instructed. However, it does not print.
I have put regular paper to does print the dimension envelopment .
Erny
11-17-2024 06:00 PM
Sorry but I'm not following your post. First, you said you couldn't print on envelopes. Then you said you're using a printed envelope and now you're talking about dimension envelopment.
If you don't mind, could you please rephrase whatever it is that you're doing. Thanks
11-18-2024 05:55 PM
Sorry for confusion.
11-19-2024 08:49 AM
What happens exactly when you insert the envelope into the manual feed slot?
