imageCLASS MF641Cw Trouble after using wireless setup for LAN connection
Terry50
my printed is connected via wired LAN.  I mistakenly set up new printer following WIRELESS instructions.  Problems ensued. How do I clear printer and start over.
1 REPLY 1
Hector
Hello,
If you would like to connect the printer to your network wirelessly, you can change the setting and connect the printer using the steps in the link HERE. Once you select the name of your network and connect by entering the password, you can try adding the printer to your computer to see if it detects the new connection. If you run into any issues, with the wifi setup using the operation panel or need help adding the printer to your computer after the connection is complete, you can contact our support team over the phone at 1-800-652-2666. Our agents would be happy to assist.
