11-29-2022 05:12 PM - last edited on 11-30-2022 09:35 AM by Danny
Ive tried the install with CD provided and also tried the recommened drivers that were on the website.
Tried from CD. Printer works, copier works but cant scan documents to the computer.
I un-installed all items from the CD installation.
I downloaded the drivers from canon website (recommended one per my cpu)
I have also gone to properties and run in administration mode - doesn't do anything
Every time I open Canon MF Toobox 4.9 I get the following message:
"A support
printer is Canon ImageClass MF 3010
11-30-2022 09:36 AM
Hi, brown34!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-02-2022 12:10 AM
In no hurry....just would like to get it to work.
I have:
i dont know what else to give. printer and copier work. I just can scan. when i open mf toolbox. i get the screenshot above.
12-02-2022 08:29 AM - edited 12-02-2022 08:33 AM
Did you disconnect the printer from USB before installing the drivers? This is in the installtion instructions:
Are you able to scan from the printer's control panel?
Are you able to scan using ScanGear?
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
12-02-2022 07:48 PM
unistall and followed the steps but it stops after step 9. Does not go to step 10.
same message as above
printer works per cable
copier works from printer & dont know how from cpu
Driver Version : UFR II Printer Driver - V20.95, ScanGear - V11.3
What is this?
Ive tried install from disc provided with purchase and recommend drivers for MF3010 from canon site.
When i do recommended for drivers I get the following three
Where do I get this one?
12-13-2022 05:54 PM
Hello Brown34,
If the driver installation did not complete, it would explain the error. The message can come up, if the scanner driver for the MF3010 is not installed on the computer. You can try removing the USB connection for the printer and reinstalling the drivers to see if it resolves the issue. You can leave the printer on and connected while performing the steps and turn off any other USB printers.
Once the cable has been removed, you can try downloading and installing the recommended setup from our website or using the setup disc again. Leave the USB cable disconnected until the setup prompts you to connect the cable.
If the setup still does not complete, I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to check what is preventing the setup from completing.
12-14-2022 08:32 PM
Ive unistalled and re-installed 3 or 4 times now. 1st time i messed up with usb being plugged in. Try 2 3 and 4 was not plugged in. Still getting the same error above. Scan Gear - do not know what your talking about. All i get is a readme file for scangear. No actual program is actually installed called Scan Gear. Ive search entire computer and only the readme file. What our the hours of customer support. I work on the phone monday through friday from 8 am to 5 pm which is typical working hours of most. This is printer/scanner/copier is for personal use.
