11-11-2021
12:53 PM
11:47 AM
My MF240 (wiresless) will scan to my computer.
When I change settings using the mfscan utility for color scan to use PDF it still scans as a jpg.
Dont seem to be able to change that setting on the scanner.
Any sugestions?
Thanks
12-31-2021 03:28 PM
Hello TwoZulu,
The MFscan utility, has two sections for scanner settings. When you click on settings in the lower left of the program, it will open a new window. At the top, you will see tabs for settings that are used when using the MFscan utilities button and another tab for the settings used when you scan using the operation panel. You can view the available settings using the link HERE.
