02-18-2024
09:55 AM
10:43 AM
What is the max resolution for MF232w printer/scanners? I have only 75, 150 and 300 dpi scanning resolutions in my scanner settings - MF232w. would like better option for scanning photos. Of course I can use my cellphone camera but would prefer to use scanner if I can increase resolution.
not sure what drivers I have on my MAC - currently running Ventura, so I guess I could download new driver and printer software - but worry that that might cause problems - would rather not mess with something that isn't broken.
02-26-2025 10:45 AM
Hello,
The maximum scan resolution for the MF232 is 600 dpi. To scan above 300 dpi, you would need to scan using our MFscan utility software. You can use the scangear option to manually change the dpi to a higher number. You can download the scanner driver and MF scan utility from our site using the link HERE.
For help with installing the drivers and software or if you would like assistance with changing the settings, you can contact support over the phone at 1-800-652-2666. Our agents would be happy to assist.
