10-28-2024
10:53 AM
11:27 AM
I have a printer here trying to print labels. Well the paper I have in the printer is secured and placed correctly but when I print something it shows no paper and has a yellow flashing light.
10-28-2024 11:04 AM
What printer and what application are you printing from?
Do you mean that the paper doesn't feed and the yellow light flashes? Are you loading more than one sheet?
10-28-2024 11:16 AM
The device name is an LBP 121/122 I’m not positive if that’s what you are asking. Yes the label papers will not feed and it starts blinking yellow.
10-28-2024 11:20 AM
Regular paper feeds OK?
Have you tried just one sheet to feed?
10-28-2024 11:27 AM
No regular paper is not working either. Yes I have tried just one sheet of paper, as well as multiple sheets. I have tried resetting the printer, undated software and unplugging it.
10-28-2024 11:32 AM
So the printer has malfunctioned. If it is outside the warranty period it will need to be repaired. You could give Canon support a call at 1-800-OK-CANON and see if there are repair facilities in your area.
