03-18-2016 10:06 AM
i need to find the model / model number in order to know which driver i need to download. please help.
i have a hp envy desktop and a canon HQS22065.
03-21-2016 08:01 PM
Hi BLUESEA.
I will be able to assist you.
Please follow the steps in the link below to download the drivers and software for the imageCLASS D1350:
How to Download and Install the Drivers and Software
Please note that the file that you download from the Canon website is a .ZIP file. When you select [RUN], it unpacks the setup folder. Please disconnect the printer from the computer and follow the instructions below to install the printer:
1. Open your [Downloads] (or [Documents]) folder.
2. You will see two icons with the name: D1300MFDriversV2095W64usEN. Double-click on the yellow folder icon with this name.
3. Double-click on DRIVERS to open the folder.
4. Double-click on us_eng to open the folder.
5. Double-click on x64 to open the folder.
6. In the folder you will see two listings for Setup. Double-click on the Setup that has the type as [Application].
7. The "MF Drivers Setup Wizard" will open. Proceed through the steps and restart the computer.
8. After restarting the computer, connect the USB cable and allow the installation to complete.
9. Print a document.
Should you need further assistance, please contact us at 1-800-OK-CANON, (1-800-652-2666), for further assistance.
03-20-2016 09:45 AM - edited 03-20-2016 09:46 AM
Hi, BLUESEA!
We don't currently support any printers with the model number you provided. You'll find the printer's model name somewhere on the top or front of your printer, usually consisting of letters (such as MX, MP, MF, MB, or IP, for example) followed by up to 4 numbers. Please let us know that and we can more readily help you.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/ContactCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 8 PM ET (7 AM to 5 PM PT).
Thanks and have a great day!
03-21-2016 09:15 AM
Good Morning thank you for getting back to me.
i dont know where to find the model number so i looked in the back of the printer and saw the number i provided.
on the front of the printer is this only - IMAGE CLASS DL350
please help thanks
03-21-2016 09:24 AM
Thanks for the information. While Canon USA has not marketed an imageCLASS printer with the model name "DL350," we have marketed a "D1350." We can see how the 1 might be mistaken for a lowercase L. If you take a closer look, could you please confirm whether you've got an imageCLASS D1350?
03-21-2016 11:29 AM
AHH , yes thats it.
i need help connecring my pc to this printer.
03-21-2016 01:29 PM
yes thats correct , can you please tell me what to do ?
thanks.
03-21-2016 08:01 PM
Hi BLUESEA.
