07-28-2025 08:21 PM
Officially, I believe 73# cardstock weight is the max for my Canon MF656Cdw printer. However, I just realized that the cardstock I purchased and want to use is actually 80# weight. Rats. Dare I attempt to use it? How risky is it to be 7# over the recommended limit? Thank you for any pro tips!
07-28-2025 09:16 PM
I've not tried using heavier weight papers in my 644 or 656. To be safe using the max specified weight is recommended. Heavier weight papers could jam the printer. It might work single sided, but I would not try duplex. Afraid I can't be more definitive. You should be able to order paper in the recommended weight online. This might be best.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
07-28-2025 11:07 PM - edited 07-28-2025 11:09 PM
You can try it. Either it works or it doesn't.
There are three properties involved in paper handling through a printer....weight, thickness and stiffness. Actually, four. The surface finish can affect grip by transport rollers.
A slightly heavier weight can be flexible enough that it's not a problem. A slightly heavier weight can be no thicker than a lighter weight. The weight (full term is Basis Weight) doesn't tell the whole story.
