Stopping a Fax
psanderson
My Cannon Maxify MB2700 series printer has been trying to send a fax, not initiated by me,  for over an hour. The STOP button does not work to cancel it and I have also turned the printer off, waited a few minutes, and then turned it on again and the same fax is still sending.  I need to print some other documents.   What should I do?
3 REPLIES 3
Have seen a few reports from others stating the same behavior (various models).
How is your printer connected in your environment?
Do you have a telephone line connected?
What operating system are you using?
Rick, thank you for your response.  My daughter knew how to re-install and update the drivers and everything seems to be working fine now.  I have no knowledge to explain how she did it.
Psanderson
The uninstall and reinstall of the printer's drivers is the same information posted by others which I found as well.
