Software Cannot Communicate with MF731Cdw Scanner
Tedeye
Hello Gals and Guys -
I have Canon MF731 Printer/Scanner.  I don't use the scanner much, but today when I tried, the software stated it could not communicate with the scanner.  So far I've unplugged the cable and turn it off/on, but neither of those fixed the issue.  The printer works normally, so is there something I can try to fix the scanner?  Thanks for any help.
2 REPLIES 2
What OS and build are you running the printer with?
How is it connected and to what?
Is a specific error code displayed?
Did it ever work correctly (previously)?
"Unplugged the cable and turned it off", means?  Power cord, ethernet, USB... ?
Thanks Rick.  I appreciate the help.  Whatever you did, it worked because I just tried and it scanned perfectly.  I've had the thing for a while and it always worked, but I don't use it much.  The error said it couldn't connect to the scanner or something akin to that, but as I said, the printer worked normally.  Thanks again.
