01-21-2024 01:44 AM - edited 01-21-2024 01:53 AM
Using a mac running Sonoma (macOS 14.2.1) I don't seem to have an option as to whether I want to print two-sided or not. I've dug through the dialogs and it's just not there, or at least that I've found.
How can I choose, without changing the system defaults, whether I want to print on one side or both?
01-21-2024 08:06 AM
What applications are you printing from? While I'm using a different laser printer with macOS Sonoma (imageCLASS MF653Cdw), when viewing print settings in Pages, Keynote, Preview, Mail, TextEdit, Photoshop, Illustrator, I see the double-sided option.
I didn't check all my software, but from that list, that's a very good representation.
01-21-2024 11:44 AM
I've checked the application print options in Chrome, Adobe Acrobat, and Photoshop (so I think Photoshop is the only overlap there) and the option isn't there. More importantly, however, it's not in the system print UI (where in an application, you can select an option like "printer" or "print using system dialog") to see the settings that are independent of the application you're printing from. No 2-sided option in any of those.
01-21-2024 12:52 PM
What paper size are you using? About the only thing I see in the User Manual is that automatic 2-sided printing won't be available for certain paper sizes. See pages 630 to 632.
01-21-2024 01:04 PM
US 8.5x11
I'm thinking I should reinstall the driver. Any recommendations there? I usually I used whatever loaded by default, but when the printer went to sleep I couldn't print to it. I manually loaded the driver to resolve that (per a post found somewhere...maybe here, I forget).
