02-07-2024 10:44 AM - last edited on 02-07-2024 12:15 PM by Kristoff
Just purchased a new Imageclass laser printer. How can I tell if remote printing is available?
02-07-2024 11:06 AM
Thanks for joining the conversation, dlherg!
So that the Community can help you better, we need to know exactly which imageCLASS printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-07-2024 12:14 PM
Thanks Danny My printer is an Imageclass LBP632Cdw (I thought about that after posting but there wasn’t a way to edit 😣)
02-07-2024 01:05 PM
Hi dlherg... to edit a post or reply you have created, use the drop arrow menu and select Edit.
You can edit the text in the message body or the title if its your topic.
Regarding your question. Can you please clarify what you mean by remote printing?
Are you trying to print from an App on your mobile device (example).
Thanks. Looking forward to your reply.
02-07-2024 01:15 PM - edited 02-08-2024 08:27 AM
Thank you Rick!
By remote print I mean if I’m at work and want to send something to my printer at home. Is that possible?
I’ll clarify. (And I appreciate the lesson on post editing @shadowsports)
I believe I’ve heard/seen that printers are capable of printing remotely via an email address or an ip address (not sure exactly how it works) so if you are not at home but have internet access you can send documents to your printer. Is that possible with this printer and if so how do I enable it?
02-09-2024 02:11 PM - edited 02-09-2024 02:26 PM
I am familiar with the feature. I had it on a few HP's I owned. I just wanted to make sure this was what you were describing.
I don't believe this is supported on your device. The feature is an "extension" to the devices webserver whereby you register the device with the manufacturers cloud and create a destination email that you can "send to" and if there are attachments (like a Word doc or .PDF) its prints those attachments which are then waiting for you when you arrive home. I rarely used it but it was somewhat useful. This was also supported by Google Cloud Print, which unfortunately Google terminated support for.
Without this type of "service" another way to do this would be with VPN, whereby you would VPN to your home network and then choose the printer on your home network as the destination for a print job.
Please look at the printers i-FAX option. Its not the same as true "remote" printing, but might work for you.
Give this a try 😉
02-09-2024 06:18 PM
Thank you again @shadowsports.
I see the email setting but there’s no i-fax option there. I’ve attached images for reference…
