12-30-2019 12:07 PM
PLEASE help!
i have a canon image class d420, i have been using this printer for years, try to scan and am getting the same error "cannot start the scaner driver while it is in use by another application or user.
I have downloaded the new printer drivers, and restarted my computer multiple times!!!!
i have a mac os catalina version 10.15.2
PLEASE help, i have to scan documents for work!!!!!
thank you in advance
mimi shea
12-30-2019 12:12 PM
The Canon Community Forum is not for immediate assistance. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE. You can also contact technical support at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
We hope this helps!
01-03-2020 01:48 PM - edited 01-03-2020 01:53 PM
Hi mimilshea.
In addition to the printer drivers, you will need to download and install the scanner drivers at the D420 Drivers & Downloads page. They are provided in a separate installation package from the printer driver package. If the printer was previously installed before updating to OS 10.15, you may need to remove it from the list of printers or reset the printing system, then add it back.
If you have both Image Capture and the MF Toolbox / MF Scan Utility open at the same time, it's possible for one to interfere with the other; ensure only one piece of scanning software is up and running. If the problem is lingering after a previous scan, before updating the scanner drivers, power off the printer, wait ~ 30 seconds, then power the printer back on. This will normally end any lingering scan processes.
If the D420 is still unable to scan after installing its scanner drivers and power cycling the printer itself, ensure the security software and settings on the Mac is allowing the printer to communicate and interact with the computer. Also check that the USB connection between the printer and computer is not damaged, and replace the cord if it is.
