Problem with Canon Imageclass MF414DW (Scanner) and iOS Catalina 10.15.6 - PLEASE HELP!!!
DavidB1
Hello,
Thank you in advance for your help!  I have an iMac computer, running iOS Catalina 10.15.6, and have a Canon Imageclass MF414DW that I use in my home office.
I recently reconfigured my office space, and am now trying to reconnect my printer to my computer.  I have updated the drivers for both the printer and the scanner from Canon's website, but am now having problems scanning documents from my printer/scanner to my computer.  When I place documents in the feeder, and attempt to operate the scanner from the screen on the printer, it states "Connect to Printer."  I have reset all the printer settings, and am able to print documents from my computer to the printer, but it does not want to cooperate when I try and scan documents from the printer/scanner to the computer.
Any guidance that can be provided would be greatly appreciated!!
Thank you again.
2 REPLIES 2
Current drivers (414dw) for OS Catalina list support through 10.15.5, but its likely that support for 10.15.6 exists too.
How is this printer connected... ?
Do you receive an error message?
Do you have the Scanner Driver installed v2.15.2?  (Believe) this is the MF utility from the computer, but it won't hust to have it installed.
Be sure the connection type is properly selected.
Darius
Whiz
Hi DavidB1.
When a new version of Mac OS rolls out, an updated driver can take a couple weeks to catch up, depending on how new .  You can try using the current Mac OS driver, though it may experience some problems of which we're not aware.  We appreciate your patience while we work to update the driver to be properly compatible with OS 10.15.6.
