12-04-2015 09:27 AM
Printer uses way too much colored ink. Is there a way to only print in black ink without having to manually use the "black" button each time?
12-09-2015 09:02 AM
Hello.
If you are printing from a computer, using the Grayscale option in the printer settings will allow the item to print in black and white.
If you are copying directly from the printer, please use the Black start button to avoid using color ink for your copies.
If additional assistance is needed, find more help at Contact Us.
