11-04-2023 01:15 PM
The message states to remove the jammed paper fom the back drawer. I have already done that and I don't see any more shreds of paper stuck. But it does not reset. I have recycled the printer power and the message won't go
away.View from back 1
View from back 2
Message on LCD
01-30-2024 04:42 PM
Hello,
If the paper ripped and the code will not clear, it looks like the hardware is damaged or a piece has been pulled into the paper path. If the code will not clear, you can try turning the printer off and on a few times with the toner out of the printer to see if any pieces are ejected. If that does not clear the code, it looks like the printer needs service. To check your service options, you can contact support over the phone at 1-800-652-2666 or log into your MyCanon.
01-30-2024 04:42 PM
Hello,
01-30-2024 07:12 PM
Hi did you get to fix this? I had a paper jam too and i cant get it out anymore. Hope you can help thanks
01-30-2024 07:19 PM
No. It definitely required service, as confirmed by Hector above. Since I was out of warranty and Canon does not provide non warranty repair options, I ended up throwing it away.
02-01-2024 09:56 AM
ugh ok, im out of warranty too so my fate will be the same 😞
10-21-2025 07:35 PM
Ridiculous! Mine is basically new and I’m dealing with this rn it’s insane. There’s a tiny piece of paper shred I can’t get to it just needs to run and it will clear it but it refuses to do anything. I’m gonna have to tear the whole thing apart.
10-21-2025 07:36 PM
How is there no way to clear the error programatically so that the printer will simply run and clear the tiny little spec of paper I can’t get out? This is insane I need to print!!
