01-08-2023 04:12 PM
Hi, I cant get rid of the paper jammed warning on my Canon Image Class...No paper is jammed, I have done a reset, but cant figure it out. I have tore it apart for tiny pieces of paper but the last 3 pages I printed are all in tack with not tears. I am baffled. Any suggestions. I have had it 4 years, maybe its toast. thanks
01-10-2023 10:39 AM
Hi, Cherilynn1955!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
01-11-2023 11:47 AM - edited 01-11-2023 11:49 AM
Currently, can any of the native maintenence tasks run? If yes, try running the "Clean Fixing Assembly (Reduce Paper Back Side Stain)" a few times. This process feeds a blank sheet of paper through the path to clear excess toner.
Is there any stuck paper around the toner cartridges? 🤔
01-11-2023 06:32 PM
Canon ImageClass MF735CDW/MF733CDW
01-11-2023 06:36 PM
HI, THANK YOU FOR ANSWERING..NONE OF THE MAINTENANCE TASK WILL RUN. I HAVE HAD THIS MACHINE APART, INSIDE OUT AND THERE IS NOTHING JAMMED. I LOOKED AT THE LAST 3 SHEETS THAT WERE PRINTED AND THERE ARE NO TEARS, RIPS OR ANY PIECES MISSING OFF THEM. A THOUGHT THOUGH, I HAVE BEEN USING ANY AFTER MARKET INK CARTRIDGE. I USED ONE BEFORE, IT LASTED OVER A YEAR, NO PROBLEMS. I NOTICED THAT THE BLACK WAS LEAVING STREAKS ON THE PAPERS. NOW IM WONDERING IF THERE IS A POSSIBILITY THAT THE AFTERMARKET INK CARTRIDGE IS THE PROBLEM AND MAY HAVE RUINED THE SENSOR. I HAVE DO A HARD RESET ON IT AND THAT DIDNT WORK EITHER. THANK YOU FOR YOUR TIME. IF YOU HAVE ANY OTHER IDEAS, PLEASE LET ME KNOW. I HAVE PURCHASED ANOTHER PRINTER IN THE MEANTIME, BUT I DONT WANT TO GIVE UP ON THIS PRINTER.
01-11-2023 06:51 PM
Try reaching out to Canon Customer Support. They can advise about sending the unit out for repair. Just consider if it is cost justifiable. 🙂
01-11-2023 07:02 PM
THANK YOU!! ITS NOT JUSTIFIABLE. THE MACHINE WEIGHS 30+ LBS, SHIPPING WOULD BE VERY EXPENSIVE. I HAVE HAD IT FOR 4 YEARS. I DID HAVE THE CANON CARE PAK BUT THAT EXPIRED. I WILL LEAVE IT SET UP, I CAN STILL SCAN AND FAX WITH IT, SO ITS NOT A TOTAL LOSS...THANK YOU AGAIN FOR YOUR TIME!!
01-11-2023 07:17 PM
