11-03-2014 12:22 PM
Does the canon mf6160dw automatically update the time and date header for daylight savings time?
If no, how do ypou update the header?
11-05-2014 11:58 PM - edited 11-05-2014 11:59 PM
Hi jcclifford.
I will be glad to assist you.
There is an option to specify whether the machine will use daylight saving time. However, it will need to be set by specifying the starting and ending dates. Please follow the instructions below:
] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
1. Select <On> using [
] or [
] and press [OK].
2. Specify the starting date of the daylight saving time.
Select <Month> using [
] or [
] and press [OK].
Select the starting month and press [OK].
Select <Day> using [
] or [
] and press [OK].
Select the starting week and press [OK].
Select the starting day and press [OK].
Select <Apply> using [
] or [
] and press [OK].
3. Repeat Step 2 to specify the ending date.
To change the current time, repeat steps 1 - 3, on step 4, select [Current Time Settings], and then follow the instructions below:
Use [
] or [
] to enter time and date, or to switch between <AM> and <PM>. To move the cursor, press [
] or [
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
