MFC455dw - will not feed document loaded on automatic document feeder, scan function enabled
bfodiman
Status monitor says "scanning" - but the ADF does not feed it.  I tried feeding it manually.  Also no results.  The store location, my notebook computer, is enabled and functioning.,
4 REPLIES 4
Stephen
Moderator
Moderator
Hello!
I’m sorry to hear that you’re having trouble with your printer. To help the community assist you better, we need a bit more information:
- Which version of Windows or macOS are you using?
- How do you connect to your printer: via USB or Wi-Fi?
- Have you installed the Canon Drivers, Software, and Utilities from https://canon.us/MF455dw-software
Any additional details you provide will help the community better understand your issue.
If you are in the United States and need urgent support, please click HERE to visit your My Canon Account for personalized support options.
If you are outside the USA, please click HERE to find support options for your country.
Thank you, and have a great day!
There isn't a method to "manually" feed documents through the ADF.  It should sense when a document is loaded but the feeding is automated.
The first thing to test is load a piece of paper into the ADF and perform a copy function from the printer's LCD.  If that works, the printer's hardware is probably working normally.
To provide furrher assistance, next steps please answer @Stephen's questions.
Which version of Windows or macOS are you using? Windows 11, all updates installed
- How do you connect to your printer: via USB or Wi-Fi? Wi-Fi
- Have you installed the Canon Drivers, Software, and Utilities from https://canon.us/MF455dw-software Yes
The ADF works fine for copies.
I no longer have personalized support options - I waited too long because I was just using the (excellent) copier function for my home office, scanner at work.
See 11/8/2025 answer:
I
