07-16-2018 09:30 AM
Over the past weeks the black print has been slowly getting fainter and fainter. (The faintness is more pronounced on the right side of the page than on the left.) Color printing appeared to be OK, although not as vibrant as it once was.
I assumed the problem was that the black toner cartridge was running out of toner, even though the Utility (I'm running Mac OS 10.13.5 High Sierra) said all four toner cartridges are full. This morning I replaced the black toner cartridge and now the printer will not print black at all. Printing a test page shows the color part of the image, but no black. Printing one of my own documents prints the logos and other color text on the page, but none of the black text.
I downloaded the latest drivers from the Canon web page and reinstalled the printer drivers. That did not change anything.
Any ideas? Is it time to purchase a replacement for the Canon?
07-16-2018 09:39 AM
07-17-2018 07:32 AM
Hi ceath
I recommend cleaning the Fixing Unit to resolve the issue. If the issue continues, take out the toner and rock it 5 or 6 times to evenly distribute the toner. Re-install the toner then attempt a print job.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
07-17-2018 09:01 AM
Thanks for the advice, James. However, I've tried those approaches:
After replacing the black toner cartridge (based on my assumption that, even though the Printer Utility says I had a full cartridge, that information was erroneous and that the cartridge was actually spent), I got zero black print (although I did get some color printing as noted earlier).
I've just completed a repeat clean of the Fixing Unit (and, while I was at it, I cleaned the ITB as well). The Clean Fixing Unit process produced a page with good, solid black diagonal stripes -- so the black CAN print.
Yet when I print a regular text document that is just black text, I get nothing.
When I print a test page using the Canon MF Printer app (Printer --> Print Test Page), I get three symbols in the middle of the page: 1) a letter C with the words Unix Printing System enclosed (in poor-quality black), 2) a circle with the colors of the rainbow that looks pretty good, and 3) a gradiations of black stripe that also looks fairly muddy.
I did try turning the printer off for several minutes and then restarting it. That did not seem to make any difference.
Here I think may be the most important clue of all:
So is the problem related to the printer being unable to handle true black print, but it can produce black, after a fashion, by combining CMY ink to resemble black?
Thanks for your help on this.
07-19-2018 10:59 AM
Does anyone have ideas for what would prevent a laser printer from printing black (even after the black toner cartridge has been replaced), even though the printer can print colors fine (even approximating black by adding the CYM colors together) and even though the Clean Fixing Unit process produces a page with good dark black stripes on it?
My assumption is that the problem has less to do with the black toner and more to do with the way the printer is processing black images.
I've got a printer that is useless because it can't print black text.
07-24-2018 06:36 AM
Today I received a response from Canon (copied below). What gives?
Apparently Canon wants me to mark their reply as having solved my problem. Does no one read any more? Or is it only robots that work at Canon?
This respose is, it seems to me, an automated response to just clear the forums so Canon can check off another request completed. But it does nothing to solve my problem, which has been described in some detail.
Time to find a new printer.
Hello ${thread.topicMessage.author.login},
Your topic recently received replies.
Topic: MF8380Cdw will no longer print black
Date: ${thread.topicMessage.postDate}
Did it solve your problem?
Click here to view the replies and mark one as an Accepted Solution.
This helps others find helpful answers in the community too!
To manage your subscriptions or to change your subscription options, click here.
If this link doesn't work:
Thanks for being a Canon Community member.
Your Canon Community Team
07-25-2018 10:15 AM
Hi Ceath
Based on the described issue and the steps already performed, it is recommended at this point that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
07-30-2018 09:00 AM
I am closing this ticket. No useful suggestions here in the CanonCommunity.
Contacting Technical Support provided basically the same information with the suggestion that I take it in for repair. Since the repair will cost more than replacing the printer, I'm scraping a very nice printer that has apparently one fatal flaw.
07-25-2018 10:09 AM
Hi ceath,
I recommend cleaning the Fixing Unit to resolve the issue. Please click HERE for instructions to clean the Fixing Unit.
If the issue continues, take out the toner and rock it 5 or 6 times to evenly distribute the toner. Reinsert the toner then attempt a print job.
