MF753CDW II – Network Not Recovering After Sleep Mode
shdwlark
Hello,
I’m reaching out for guidance on a new MF753CDW.
I’m hesitant to post since I’ve seen similar reports without clear resolution, but I’m hoping someone can help.
Here is what I am experiencing:
  • Brand new MF753CDW II
  • Static IP configured
  • Connected via 2.4 GHz WiFi
  • 2.4 GHz and 5 GHz are separate dedicated SSIDs
The issue:
  • When the printer enters sleep mode for extended period of time (Deep Sleep), it does not properly recover network connectivity.
  • If I manually wake it using the LCD screen, it still shows WiFi connected.
  • However, no device can reach the printer.
  • It does not respond to print jobs or pings.
  • I must power the printer completely off and back on to restore connectivity.
Additional notes:
  • Tested from 5+ devices
  • Windows and Linux systems
  • Same behavior across all systems
  • At network level pings are 100% when awake but in deep sleep no pings are returned.
  • If I prevent the printer from sleeping (currently set to 120 minutes), it works 100% reliably
It appears the printer does not properly rejoin the network stack after deep sleep, even though the display shows WiFi connected.
Has anyone found a solution for this?
Is this a firmware issue, sleep setting issue, or known bug?
Wireless Power Save Mode
Power Save Mode:
Off
Version Information
Main Controller:Boot ROM:DCON:Language:
02.02
02.02
10.02
01.04
Thanks in advance!
After a month of this, I give up and bought a Wi-Fi to RJ-45 bridge and that’s working great no issues nothing whatsoever. It was a tp-link re220 for $15 from amazon.
9 REPLIES 9
koronajr
I have experienced the same issue with my Imageclass MF753Cdw II printer.  Although, it doesn't happen all of the time.  It will wake up if I tap the touch screen but, at other times, tapping the touch screen will not wake up the device.  When this occurs all print jobs sent to the printer were stuck in the queue.  Shutting the printer off and thern on clears this issue.  I have updated the firmware with the same result. (I had to update the firmware using my computer, directly connected to the printer, because I kept getting a communication error when using the internet.)   It appears that other posts have pointed to a network setting.  Since I'm a novice, I don't know where to turn to correct this issue.  Please help!
different
Same here, with an MF752Cdw II... It is very annoying, cause sometimes it works, sometimes not. Hoping for a quick fix on this.
koronajr
How do you prevent the printer from sleeping?  I didn't see any settings that would let this happen.
I'd like to offer the following information so that this thread doesn't become derailed.
The op decided to use a Wi-Fi to ethernet adapter, probably because the distance between the router and printer to run ethernet was impractical.
Alternative:  Assign or reserve a static IP for the printer on your wireless network. This is done on your router.  Then install the printer as a TCP/IP device on your computers.  Relying on DHCP,  host name resolution or ARP Is not reliable for persistent devices (printers) on a network.
different
Dear Rick,
thanks for the tip, but already done that. The problem lies elsewhere - as the printer can't see any of the nearby wireless networks when coming from sleep. I click the Home button, then the wifi icon next to Status monitor (which shows a connected state!), then hit Wifi settings. It starts a scan and always returns a "Could not find any access points" error.
Till I do not power cycle the printer, after it shows plenty of AP's... So, good old Windows trick is working, but it is really frustrating - especially when you scan & send documents on a bigger scale and can't be sure of the delivery.
Even after sleep on rj45 it worked no problem
Did all that still never fixed it thus I went with a hardwire network connection that allowed it to wake via a print demand and still print after sleep wireless never recovered.
vermsky
I have the same issue. I have and MFC753 CDWII and have an Asus XT9 mesh router/node. I assigned a static IP and disabled IPV6. I also have it auto wake in the morning but it eventually goes back to deep sleep in a couple hours. I tried turning of sleep mode but the screen seems to stay on the whole time so I noped on that. Software update done and still no luck.
I did find a workaround by using a web browser and logging on to the management page using the static IP I assigned (ex. http://192.168.12.34).
Login using administrator mode using the PIN you assigned (if you already did. Not sure what the default one is but it may be 7654321). Close the Initial Settings frame and click on the Settings/Registration button on the right (if you don't see a close button in this frame, reduce the page size as it may just be hidden and the frame doesn't move).
On the Settings/Registration page, you will find a Restart Device button. Click on that and your printer restarts and reconnects to the router.
This is highly inconvenient but at least it's not as inconvenient as walking to the printer just to wake it up. I think the printer job is just not sending a strong enough signal to the NIC to wake it up from its slumber since the above method I described worked.
