MF753 remote UI
cyberwasp
Enthusiast
On this printer, is there a way to turn on Remote ui after the setup process is complete. I went through all of the menus but couldn't find a place to turn it on. Is it only available during setup? TIA
Rick. Sorry, I finally got to log in. The Menu button was not showing up, so I did a full reset and more menus appeared including "Menu. Thank you!!!!
6 REPLIES 6
You can access the remote UI using a web browser.
See this for assistance:
Starting Remote UI - Canon - imageCLASS MF753Cdw / MF751Cdw - User's Guide (Product Manual)
Note you will need to create a PIN during set up.  Keep this in a safe place.
On my printers control panel when turn on there is a general tab listing ways to print. There is no Menu button. I've gone through the six Custom tabs. None of which have a " Management Settings  License/Other1 Remote UI Settings" anywhere to be found.
Did you see the reference from the user guide I posted?  Enter the machine's IP address in a browser.  This opens the remote UI on the printer's webserver.
Yes I did that only to receive the message:ui.JPGui.JPG
At the printer there is no management setting menu as described in the link you have abouve. The only thing I could find on the menus for remote ui was under application library guide that show a nice little photo of a address bar.
All I did was point you in the right direction 😃.  You figured it out.  Good work.
