MF743cdw - Application Library
prock
good afternoon,
I needed to know if it was possible to block the screen to just one page in the Application Library
thank you
1 REPLY 1
Darius
Whiz
Hi prock.
The Application Library is unable to disable the Copy, Scan, Fax, or Memory Media Print, as well as being unable to affect the menu options located on the periphery.  If you wish, you may disable the other quick-use options, leaving up to 4 of those extra options enabled, and thereby restrict the number of options to a single screen.
Application Library: https://oip.manual.canon/USRMA-2122-zz-OP-enGB/
Accessing the Remote UI: https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-mcn_mng-rui-strt.html#0833_h1_01
Friends and Family
