04-21-2020 01:20 PM
Running Mac 10.13.6
Attempting to scan directly to computer.
Error message: Could not start application because the neccessary information is not registered. Register information from the Remote UI.
Navigating the Remote UI, I can't find how to register or preset destination. I registered the printer on Canon website today.
Any advice or assistance would be appreciated.
08-29-2023 05:17 PM
This is a 3 yr old topic. Its best to start your own thread to receive accurate / up to date information.
See the last link under Option 6
04-22-2020 09:49 AM
Instructions for scan to preset destination:
https://oip.manual.canon/USRMA-2122-zz-OP-enGB/contents/SS735_applib_0010.html
04-23-2020 06:13 PM
I appreciate the link to the instructions, but is there something else required in addition to that? "Scan to Preset Destination" is enabled in my application library. I even tried selecting the "initialize" in the Remote UI application library and nothing was started.
04-23-2020 07:32 PM
Application Library is not visible in my Remote UI portal. How to add?
04-23-2020 10:52 PM
05-14-2020 06:36 PM
Still no luck. Printer shows error. If I try the Scan button, and select email, it says email/i-fax setting not setup in remote UI.
06-08-2020 11:11 PM
06-09-2020 03:51 PM
Hi chirano and WiseManWhite.
chirano,
If you're trying to directly scan to the computer, ensure the Scanner Driver & Utilities have been installed on the computer, as well as reinstalling the UFR II /UFR II LT Printer Driver & Utilities. They're available, free of charge, at the following page:
You may need to remove and re-register the MF741Cdw in the printers list after the drivers have been installed.
WiseManWhite,
More information on registering a scanning or I-Fax destinations through the Remote UI may be found at the following page in the MF741Cdw's online manual:
https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-mcn_mng-rui-reg_desti.html
Note: for direct scanning, the computer will need to have the Canon-produced Printer and Scanner drivers installed; see the link above addressing chirano.
08-25-2023 02:29 PM
This link is broken. How do I set up Scan to Present Destination from the Remote UI?
08-29-2023 02:43 PM
I just used the scan utility app to set the destination to a folder on my PC!
