06-09-2022 09:40 AM
We recently purchased a MF741Cdw and for some reason it changes its IPV4 address overnight. I have assigned the printer a static IP but that doesn't seem to help. What is even more odd is that the IP address it changes to does not even fall into the range of my router. Any ideas? Thank you.
06-09-2022 10:38 AM
I would suggest setting or reserving a static IP on your router. If you provide the brand and model, I'll try to provide more detailed information.
If you reserve or set a static IP, it won't change. If it does, then something in the configuration was not done correctly.
