06-13-2021 03:46 PM
I have a macOS Catalina (Version 10.15.7) and been trying to print in B&W using my Canon MF733Cdw printer. There isn't a B&W option, whereas there is one for my other printer (see image below). I tried using a different Mac laptop and it does indeed have a B&W option. It's just my Mac problem I believe and hope to fix this ASAP. How do I make this B&W setting show up? Thanks!
07-20-2021 04:04 PM
Hello there,
The black and white option will appear under the drop down that says Layout. Once you click on the drop down, you can select the option for Basic. Under the basic settings you will see the option to change the color mode.
You can also adjust the color settings using the operation panel using the steps in the link HERE.
