03-05-2022 08:48 PM - edited 03-05-2022 08:51 PM
The display says "Paper Jam / Open Left Cover" without any code. I don't think the jam is real.
I put a camera inside the paper tray and upload the video to youtube:
In the video, I see the following things.
The top of the 2nd piece of paper is right at the end of the registration roller. The paper doesn't go a bit beyond the registration roller. After I open the left cover, I can't just pull that single piece of paper out. I have to manually roll the roller to get the 2nd paper out.
On page 111, the service manual talks about a "Retry Pickup":
At first, I thought maybe SR11 was faulty and couldn't detect the paper. That would make the machine do that "retry pickup".
But I am not sure because I can't even see an error code for the jam.
Does a jam always have an error code? If that is the case, how to see that code?
I have tried:
But that history is blank.
I also did several sensor tests using the normal sensor mode (not the latch mode).
Test of the cassette paper sensor (SR9):
When the tray has papers, CAS = 1. When the tray has no paper, CAS = 0.
What I see: 0/tray has no paper, 1/tray has paper.
But page 224 (F14-14) of the manual says the exact opposite: "CAS: Cassette paper sensor (SR9): 0/Document presence, 1/Document absent".
What I see: 0/no paper, 1/has paper.
The manual says the exact opposite: "REG: Registration sensor (SR11): 0/Document presence, 1/Document absent”
What I see: 0 0/no paper, 1 0/has paper.
The manual says the same thing: "Delivery sensor (SR5): 1/Document presence, 0/Document absence.”
03-17-2022 03:38 PM
Hello,
From what you are describing, it looks like the printer needs service. You can check your available service options using the link HERE to access your MyCanon account. You could also call support at 1-800-652-2666. Our agents would be happy to assist in checking what is causing the issue and can provide any available service options.
