09-03-2021 05:54 PM
Please help.
Printer is printing with a vertical black line. 60% of toner is still there as per the consummable diagnostic.
Any user self maintenance will fix this?
Thanks
11-11-2021 02:33 PM
Hello Gprasadhr,
If you are getting vertical lines in your prints, you can try cleaning the image transfer belt(ITB) or the fixing assembly. If either of those items are dirty, it can cause streaks/smudges in the prints. You can find the cleaning instructions for the printer using the link HERE. If Cleaning those two items did not resolve the issue, you can also try removing all of the toner cartridges and inspecting the inside of the printer for any loose toner powder that is inside of the unit. You can wipe up any toner power with a damp lint free cloth.
04-02-2022 03:35 PM
Do you know if you can replace the ITB with out replacing the whole assembly? In either case, do you know how to do it (remove and reinstall)? My ITB is shredded to pieces.
04-12-2022 01:17 PM
Hello Knoxduder,
Unfortunately, wee do not have any repair manuals that we can provide. If the fixing assembly is damaged, I would suggest contacting our support team at 1-800-652-2666 to see what service or warranty options you might have.
