05-11-2014 09:44 AM
I use iMac with OSX 10.9.2. I installed latest version of MF Toolbox, upgraded the firmware to 15.04. I can scan with USB. Wireless works because I can print with wireless. However, when I disconnect USB and try to scan through wireless network, either from iMac or from MF4890dw, it will scan the first page and hangs for a while, then MF2890 will show "An error has occurred [close]" and the computer will pop up an error window:
"Cannot communicate with the scanner.
The cable may be disconnected, or the scanner may be turned off.
Check the scanner status and try again.
Scanner driver will be terminated.
Error code: 200010"
MF4890dw is communicating with iMac because it will scan the first page and it will tell me to put paper in the feeder.
Any help is appreciated.
05-13-2014 04:38 PM
Hi rjlin.
I know this error is frustrating and I will be glad to assist you.
I recommend uninstalling and reinstalling the ScanGear driver and the MF Toolbox software.
Please follow the instructions below to uninstall:
Next, reinstall the Scangear driver, and then add the scanner in the MF Toolbox [Network Settings], by following the instructions below:
After adding the scanner, please follow the instructions below to scan a document:
I hope this information is helpful to you. If the error persists, please contact us at 1-800-OK-CANON (1-800-652-2666).
05-19-2014 04:59 PM
I tried this 3 times over the last week. No, it still does not work and gets the same error.
I even tried it on a Windows 7 Laptop. Same except error code is 155,0,0.
07-08-2014 03:44 AM
I'm having the same error on my 4880 wireless. It previews the scan but it comes up with that **bleep** error. Why hasn't the tech responded? Clearly his generic answer didn't help.
09-25-2014 01:36 AM
I am having the identical problem, but on Windows 7. Reinstalled drivers and MF Toolbox, to no avail. The problem appeared out of nowhere. Any remedies?
09-25-2014 08:00 AM
09-28-2014 10:25 PM
Hi derekw.
If uninstalling and reinstalling the drivers and MF Toolbox software did not resolve the issue, it is recommended that you contact us at 1-800-OK-CANON (1-800-652-2666). While I understand that the forum may be your preferred method of communication, the real time feedback of a live technical support call would be very beneficial in this case.
07-19-2016 11:47 AM
Canon support helped solve this issue for me.
The problem was the wireless signal strength. I moved an Access Point into the room with the printer/scanner, and the scanning function began to work.
Apparently, scanning requires a stronger signal than printing.
