01-18-2018 01:49 PM
I have a Canon mf4880dw which sometimes slows down when making multiple copies. This is not a wireless issue (as I have seen in some discussions on this bulletin board), since I am using the copier function, not the "printing from computer" function. No error messages appear, and the toner is not low. I have not been able to zero in on when this happens, but it is frustraingly slow when it does happen. Any ideas?
05-03-2018 11:27 AM
Hi mdgoodman
You can adjust the image quailty of copies according to the types of documents. A correct selection is necessary for the optimal reproduction of the document. Adjusting the image quality setting can either speed up or slow down the speed depending on the option selected. For example, select "TEXT" for the image quality to see if that speeds up the copies. Please click HERE for details.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
