11-01-2014 03:35 PM
I just purchased a MF4880DW which is suppose to have 2 sided printing capabilities according to the manual but the machine itself does not have the 2>2 option. The menu only provides 1>2 sided option not 2>2 sided option as shown in the manual as available on this model. Can you please assist? Thank you.
11-03-2014 11:51 PM
Hi RonPro.
The imageCLASS MF4880dw only supports making double-sided copies from single-sided documents [1 -> 2-Sided]. The MF4890dw supports both double-sided and single-sided copies [2 -> 2-Sided]. To create a single-sided to double-sided copy [ 1 -> 2-Sided], please follow the instructions below:
] (COPY).
] or [
] to highlight <2-Sided>, and then press [OK].
] or [
] to highlight <1->2-Sided>, and then press [OK].
To specify the 2-Sided copy format:
] or [
] to highlight <Format Settings>, and then press [OK].
] or [
] or [
] to highlight the orientation of the original document, and then press [OK].
] or [
] to highlight how to open the output, and then press [OK].
] or [
] (Start).
To copy a document by placing in the feeder:
To copy a document by placing on the platen glass:
] or [
] to highlight the size of the original document, and then press [OK].
] or [
] (Start).
] or [
] to highlight <Start Copying>, and then press [OK].
