MF452DW Slow Wireless Printing
evensong
Hello all, I have an MF452DW all in one wireless printer. When I print a document to the printer from my laptop, phone or iPad, it takes quite a long time for the printer to print the document, sometimes up to a minute. Wonder if anyone has had this issue and solved it and if so, what the solution is
1 REPLY 1
Hector
Hello Evensong,
If you are running into slow printing speeds over wifi, it will usually point to a weak signal or a drop in network communication. In this situation, you can try unplugging the router from the power for 5 seconds and then plugging it back in. Once the network is back up, you can try printing again to see if the speed has improved. You can also try moving the printer so it has a better connection to the network.
