03-29-2023 05:08 PM
Just bought a Canon MF264DwII (my fifth Canon network printer). Installation seemed easy, and it connected to the network easily. I can also connect to the printer via the browser/UI/IP address.
But the Canon MF device driver utility doesn't see the printer. I try searching the network (both on same network) and I search by the IP address (same one I use to access via the remote UI), and it won't find the printer.
HELP!
03-29-2023 05:24 PM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know which operating system is running on your computer (i.e. Windows or macOS and which version). How are you connecting and what error message? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
