MF imageclass 4350 (black &white laser printer) compatible with WINDOWS 8.1?
mybrojer
MF imageclass 4350 (black &white laser printer) compatible with WINDOWS 8.1?   WINDOWS 8.1 recognizes I have printer attached, but it says flatly "No driver!"  I have run all the drivers from CANON and then attached the printer.   But, still it doesn't work!   Nothing from CANON sez" SETUP...........
1 REPLY 1
Patrice
Whiz
Hi mybrojer.
I will be glad to assist you.
The file that you download from the Canon website is .ZIP file.  When you select [RUN], it unpacks the setup folder.  Please disconnect the printer from the computer and follow the instructions below to install the printer:
  1. Open your [Downloads] folder.
  2. You will see two icons with the name: MF4350_MFDrivers_W64_us_EN.exe. Double-click on the yellow folder icon with this name.
  3. In the folder you will see two listings for [Setup].  Double-click on the [Setup] that has the type as [Application].
  4. The "MF Drivers Setup Wizard" will open.  Proceed through the steps and restart the computer.
  5. After restarting the computer, connect the USB cable and allow the installation to complete.
  6. Print a document.
I hope that this information is helpful to you.  Should the error persist, or your need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
