Light Printing on MF267DW vs MF232W
RichR
Good evening,
I own a MF232W and a MF267DW II and both have been given static IP addresses which have been excluded from being re-assigned by DHCP.  Every one of my systems have been configured (Win 10 Pro and Win 11 Pro) to use either on for either UFR II or PCL 6, where applicable.  I have noticed that when I print the same document from the same document using UFR II driver that the 267 will print much lighter than the 232.  I was wondering if anyone else has had this happen to them.  Basically for me, I won't print my documents to the 267 because that are too light and the grayscale are very light.  I have no problem printing to the 232w as it prints really BLACK however it does not have fax or a ADF whereas the 267 does.  I can't understand if both are using the same UFR II driver why one would be lighter than the other.  Has anyone else run into this problem before and if so have you found a solution so that the 267 would print as dark as the 232?
Thanks in advance for your help.
1 REPLY 1
Hector
Hello,
We would be happy to assist, but we would need some additional information to assist further. You can reply to this message with the information below and we can provide some troubleshooting steps or suggestions. For a more immediate resolution I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
1. What program are you printing from?
2. Do you run into the same issue when trying to make a copy?
