09-17-2024 07:25 PM
I have an image class lpb622cdw. The starter black toner ran out and I just installed a canon 54h toner. Now the black will not print, but the other colors are still printing fine.
07-30-2025 10:46 AM
Hello,
If the prints are completely blank after changing the black toner, you can try removing the toner to check id any packing material is still attached the toner cartridge. You can check for any protective film or orange material that needs to be removed. If you continue to run into any issues, I suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
08-02-2025 08:39 AM
Last year, I already did as you advised. When I contacted Canon support, I did some troubleshooting under guidance with Canon staff. There was no fix. When I tried to return the cartridge, I was advised that returns are only accepted within 15 days. I had bought the cartridge to have on hand when I got the warning that the ink was low. Since I was not refunded for the cartri, I bought a Brother printer instead.
