Imageclass LBP632C always trying to use multifunction tray no matter the setting ios/macOS/windows10
bebimbap
doesn't matter if i use phone, mac, or pc, the printer will only print from multifunction tray and i have to manually select the drawer every single time
i have tried using system manager mode and changed the settings in there.
i have also tried to change settings on the printer and removed all paper sizes from the multifunction tray
is there anyway to completely disable the multifunction tray? if canon deleted the multifunction tray i would kiss a lot of feet
2 REPLIES 2
bebimbap
I've always used brother printers before, and never had an issue where i always always always had to manually select the drawer for every single print job no matter what source it is, like my phone.
Hello,
We would be happy to assist, but we would need some additional information to assist further. You can reply to this message with the information below and we can provide some troubleshooting steps or suggestions. For a more immediate resolution I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
What size and type of paper are you trying to print on?
What is the specific message that appears on the display when you run into the issue?
