Imageclass D1320
Karen1000
How do I copy the following:
2 one-sided sheets onto 1 paper double sided, front and back - using the top feeder.
Thanks!
1 REPLY 1
Patrice
Whiz
Hi Karen1000.
Please follow the instructions below to copy a 2-sided document to two sides of the paper:
1. According to the paper size for 2-sided printing, ensure to set the paper size switch lever accurately.
* If not securely attached, documents may not be fed properly, or jammed.
(1) Open the 2-sided unit cover.
(2) Securely place the blue color paper size switch lever (A).
  • A4: Pull
  • Letter, Legal: Push
(3) Close the 2-sided unit cover.
2. Place a document in the feeder.
3. Press [ ].
4. Press [ ] (2-Sided).
You can display the setting screen also by selecting <2-Sided> in the copy mode screen.
5. Select <2->2-Sided> with [ ] or [ ] and press [OK].
If you want to specify how to open original or copy
(1) Select <Format Settings> with [ ] or [ ] and press [OK].
(2) Select <2->2-Sided> with [ ] or [ ] and press [OK].
(3) Select the orientation of the original document with [ ] or [ ] and press [OK].
(4) Select how to open the original document with [ ] or [ ] and press [OK].
(5) Select how to open the output with [ ] or [ ] and press [OK].
6. Press [ ] (Start).
I hope this information is helpful to you.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666.
