03-17-2017 01:02 PM - edited 03-17-2017 01:11 PM
The top section of each line in the shipper and ship to sections are being cut off when printing labels. This only seems to be happening where the text is larger (ie: Amazon Seller Central and Etsy.com). This only just started happening today. Yesterday it printed fine. I checked the toner. The cartridge is 3/4 full. I replaced it anyway, and still have the same problem. This is a serious issue to our business shipping. I really need to get this corrected. Any advice would be appreciated!
03-24-2017 12:05 PM
Hello Cheryl_H,
Before we can offer a solution to your issue, we will need some more information about your situation. Coud you answer a few questions?
(1) Which computer operating system are you using, Windows XP, Vista (32 or 64 bit), 7 (32 or 64 bit), 8 (32 or 64 bit), 8.1 (32 or 64 bit), 10 (32 or 64 bit) or Mac OS X 10.5, 10.6, 10.7, 10.8, 10.9, 10.10, 10.11 or 10.12?
(2) What size is the sheet of labels?
(3) If you were to draw a 0.25 inch margin around the sheet of labels, would any text fall between the edge and the margin?
If you need immediate assistance and you're in the USA, please click http://Canon.us/ContactCF for our US-based support. If you're outside of the US, please click http://Canon.us/4xf7 for support options.
03-24-2017 05:48 PM
1) My computer OS is Windows 8.0 (64 bit)
2) A sheet of labels is 8 1/2" x 11", 2 labels to a sheet.
3) Yes, the labels would fall within a .25" margin.
The area bing misprinted is horizontal rows (portrait orientation of the labels) on print larger than approximately 12-point font. This seems to happening when I print from a website, such as USPS, Etsy and Amazon. Everything is fine if I save the labels to my computer, then print from Acrobat.
03-25-2017 04:21 AM
i Cheryl_H
IMPORTANTIf the setting does not match the size and type of loaded paper, a paper jam or printing error may occur.
Specifying Paper Size and Type
and tap <Paper Set.>.
03-25-2017 01:48 PM
All of the settings are correct. The error is happening with web-based email programs: USPS, Etsy, Amazon. But the print is perfect when I save the label image to my desktop and print from Acrobat. I'll try to contact Support.
Thank you!
