10-17-2024 04:15 PM
I am looking for the procedure to either reset the System Manager PIN or factory reset the printer for Canon ImageClass LBP162dw printers. They were set up by a previous technician and the PIN used was not documented. The 7654321 default pin did not work.
Thanks
10-17-2024 06:32 PM
If the default PIN was changed and you no longer have access to it, you will need to contact support for assistance with reset. Have the model # and serial number available when you call.
Canon Support
1-800-652-2666
