ImageClass 743 - Selecting Paper size every time printing
azlife4me
Every time I want to print from a computer, I have to walk over to the printer and select paper size and then it starts to print. The paper tray is loaded with letter-size paper. The multi-purpose source is set for letter-size and is empty and closed. I have even set "Copy" to letter size. Everything is set for letter size. The printer will not print without going over to it and selecting letter size paper. I must be missing a setting somewhere. I am trying to print from the main paper tray, which it does after I select paper-size. Thanks for any help.
5 REPLIES 5
Hopefully this will help.
<Menu>  <Function Settings>  <Printer>  <Printer Settings>  <Default Paper>  Select the paper size  Select the paper type
Here's your online manual
Thank you for your suggestion. I followed them and it did not change a thing. I still have to go to the printer to select paper type after trying to print from the computer. Thanks again.
Then it sounds like you may have unintentionally changed the default paper selection or size to something other than or whats loaded in Tray1?  Look at the printer preferences (Driver) on the computer.
Here's an example
Hi azlife4me.
In addition to Shadowsports' recommendation, I also recommend checking the printer's driver to see whether the Output Method is set to Secure Print.
SecurePrint
Secure Print will require you to manually enter a pin and possibly check settings when printing.  If it is set to Secure Print (or another Output Method that requires attention), try changing it to "Print."
Thank you.
