10-21-2015 03:50 PM - edited 10-21-2015 04:49 PM
We have an Image Formula DR-7550C. Frequently, when scanning, the created PDF has the pages out of order (which is problematic with large scans). We have changed and updated drivers, updated firmware, and updated software. There is a matching scanner (same model & brand) that does not have this issue.
10-26-2015 04:03 PM
Hi jcovington.
I will be able to assist you.
So that I can best assist you, I would like to ask a few questions.
1. Which program are you using to scan the documents?
2. Are you using the same USB cable that came with the scanner?
3. Are there any devices connected between the scanner and the computer, such as a USB hub or extender?
I look forward to your reply. Should you need immediate assistance with this issue, I recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
